It is currently Thu May 23, 2013 7:35 pm
Post a new topicPost a reply Page 1 of 1   [ 8 posts ]
 Post subject: Designing ninja weapon
PostPosted: Thu Jan 06, 2011 2:40 am
After searching the googles for a while I have finally found a piece to recreate. It is...
http://m.flickr.com/#/photos/oilyanator/5329687566/sizes/m/
This will mainly be for ninjago, ninjas and samurai.
The problem is that I don't quite know how to make the original piece to cast.
I was thinking do use a pole and 2 axe pieces, but I am not sure I that will work. Any ideas?
halo Oilyanator halo
Quis custodiet ipsos custodes?
Check out my Flickr! http://www.flickr.com/photos/oilyanator/
 Post subject: Re: Help!
PostPosted: Thu Jan 06, 2011 11:15 am
your link is faulty.
PostPosted: Thu Jan 06, 2011 11:22 am
The link works fine for me...
Anyway what scale is this supposed to be? I'd be interested in seeing this in the hands of a person to have some idea of size.
PostPosted: Thu Jan 06, 2011 11:53 am
The link was broken earlier in the day, but it is all fixed now.
On a scale of size, it would have to fit a minifig so about the length of a spear and not to much longer. I would also like to add that it does not have to be purist. Also the colours do not matter as this is only am original template.
Thanks for the help so far guys...
halo oilyanator halo
PostPosted: Thu Jan 06, 2011 1:30 pm
Another point to consider is that you have to be able to attach a 1x1 'cone' to the piece to be able to inject the plastic in.
PostPosted: Thu Jan 06, 2011 2:01 pm
Had a bit of tinkering time so came up with two possible ideas...
idea 1 http://www.flickr.com/photos/oilyanator/5331019058/
Made with 2 modified telescopes and 2 modified large teeth.
idea 2 http://www.flickr.com/photos/oilyanator/5331019058/
(sorry for the bad image quality)
Made with lightsaber that will be cut to a better size, 2 hooks which the stud will be cut off from and the same 2 teeth.
The only problem with these designs is that it is very hard to attach a vent to, any ideas on that?
(a vent is something that plastic is poured through.)
Have no favourite out of these 2 and would appreciate opinions. thank you!
PostPosted: Fri Jan 07, 2011 8:05 am
Wow, you think you can change your title to something other than "HELP"?
 Post subject: Re: Designing ninja weapon
PostPosted: Fri Jan 07, 2011 8:48 am
Done and dusted!
Sorry if I am putting stuff in wrong place etc and wrong names, I don't really post topics often. Suppose I'll get better over time.
