It is currently Sat Jan 31, 2015 12:31 am
Post a new topicPost a reply Page 2 of 2   [ 19 posts ]
Go to page Previous  1, 2
 Post subject: Re: Question - Spray Paint Application Set-Up
PostPosted: Mon Nov 08, 2010 3:22 pm
unfortunately those guys are about a half inch tall so the spray primer I tried would glob up in nooks and crannies and such.
PostPosted: Mon Nov 08, 2010 4:21 pm
Protip: don't hold it so close
PostPosted: Mon Nov 08, 2010 4:32 pm
did it from almost a foot away, much further would be wasting primer.
PostPosted: Mon Nov 08, 2010 5:52 pm
Spraypaint and airbrushing are generally considered superior due to the ability to apply a significantly thinner coat than you'd ever be able to do via brush. You just need some skill and patience to get the results you want.
PostPosted: Mon Nov 08, 2010 6:01 pm
now Air Brushing I do use from time to time since it gives a finer coat then spray painting does.
PostPosted: Tue Nov 09, 2010 10:51 am
[quote="Cygnet"]
It sounds like Omi hasn't had problems using a spray primer on newsprint (i.e. no issues with sticking), quote]
So far I haven't. I usually check up on it and bring it indoors when it is dry enough to touch it.
PostPosted: Mon Jan 03, 2011 1:52 pm
Asterios wrote:
wait till you have to paint small things like these and spray paint just won't work:
I personally use brushes, but I've heard that spray-painting small items can be done by covering the parts that aren't to be colored with masking tape, vaseline, or other substances that are easy to remove/paint won't stick to.
May your cuts be clean, and your sanding smooth
PostPosted: Mon Jan 03, 2011 3:47 pm
I did that with my Master Sword.
PostPosted: Wed Jan 05, 2011 11:19 pm
I used air-brush style spray painting to lay down a solid color foundation and then detailed the rest out with a brush.
I somewhat depends on what end results you want, you know.
