It is currently Fri Sep 04, 2015 7:41 am
Post a new topicPost a reply Page 1 of 2   [ 19 posts ]
 Post subject: Question - Spray Paint Application Set-Up
PostPosted: Mon Nov 08, 2010 8:13 am
I've been working on a dry brush/rub n buff project recently, and I need to apply a spray paint primer coat. My question is, do people have special set ups to do this? My worry about just painting and then leaving on newsprint/cardboard/mat to dry only to have it stick and or peel.
I thought about setting it up on a LEGO post held by a 1x1 cylinder. The inside might not get a full application, but the only place where the paint may 'stick' would be on the inside where it wouldn't be seen.
Any thoughts?
http://uglyduck-bricklink.blogspot.com/
 Post subject: Re: Question - Spray Paint Application Set-Up
PostPosted: Mon Nov 08, 2010 11:07 am
Any thoughts?
umm spray painting LEGO? bit of an over kill wouldn't you say? they do have paint on primers too.
PostPosted: Mon Nov 08, 2010 11:25 am
I spraypaint my stuff...
PostPosted: Mon Nov 08, 2010 11:30 am
A lot of people spraypaint their stuff...
PostPosted: Mon Nov 08, 2010 11:33 am
Anyways I think a good setup would be a place that has good air flow for one.
I do the whole outside in the garage and spraypaint on the newspaper setup. :P
PostPosted: Mon Nov 08, 2010 11:38 am
too each his own I don't since the Spray paint can ruin a work real quick if not applied correctly which can be a problem on something so small.
PostPosted: Mon Nov 08, 2010 1:43 pm
I a freaky purist...I don't paint, cut or glue anything....
but it's all cool!
I love spraypainted stuff...but yah, you should use an airy area, like an open garage.
I'm Grumpy because You're Dopey!
PostPosted: Mon Nov 08, 2010 2:02 pm
Thanks for the replies.
It sounds like Omi hasn't had problems using a spray primer on newsprint (i.e. no issues with sticking), and Asterios would recommend a paint on primer.
I'll give it a go and let folks know if I run into issues.
If anyone is aware of a good, general painting tutorial please let me know.
In the interest of sharing I'm following a Rub-n-Buff tutorial from the old Minifig Customization Network by Two-Tonic Knight (http://www.minifigcustomizationnetwork.com/howto/902).
PostPosted: Mon Nov 08, 2010 2:46 pm
wait till you have to paint small things like these and spray paint just won't work:
PostPosted: Mon Nov 08, 2010 3:20 pm
But that's not what we're talking about now, is it? And I undercoat miniatures with black primer spray.
Users browsing this forum: Yahoo [Bot] and 0 guests
