It is currently Mon May 20, 2013 2:21 pm
Post a new topicPost a reply Page 2 of 4   [ 31 posts ]
Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Brasso Tutorial
PostPosted: Thu Oct 08, 2009 4:40 pm
What's the average speed for removing a print? I've been using Soft Scrub, which takes quite a long time- though it removes Sharpie faster, meaning that if done right I can remove Sharpie from a piece without damaging the original printing- which is handy considering how much I used to abuse those markers >_<
I'd say the Soft Scrub takes maybe as much as ten minutes to fully remove the print from a torso- how does Brasso compare to that?
PostPosted: Thu Oct 08, 2009 6:32 pm
Oreo - I have not tried to only remove part of a design, but I will test some ideas this weekend and let you know the best way to do that. The cast is off, and the hand is sore but getting better everyday. I have plenty of time for minifigures because I cannot use power tools or list anything heavy for four more weeks. Thanks for asking!
Shadow - Brasso is much, much faster. The example I showed took ten seconds to remove the design completely. The harder you rub and tighter you hold the cloth, the quicker it works. Older torsos tend to take a little longer, but when I first read about using Brasso, the tutorials said it would take a minute, but I have never needed that long. I usually do 12-15 at a time in 10-12 minutes.
Keep the questions coming everyone, and there will be the next installment soon! :)
Flickr
Life is short.....customize it!
PostPosted: Thu Oct 08, 2009 7:22 pm
[quote="shmails"]Oreo - I have not tried to only remove part of a design, but I will test some ideas this weekend and let you know the best way to do that. The cast is off, and the hand is sore but getting better everyday. I have plenty of time for minifigures because I cannot use power tools or list anything heavy for four more weeks. Thanks for asking![/quote]
Someone at Brickfest this year used a regular eraser on an indy head to remove just his beard, and it came out good. Just a suggestion.
PostPosted: Thu Oct 08, 2009 9:56 pm
Thanks so much. I'm going to have to buy some more Brasso soon :).
PostPosted: Fri Oct 09, 2009 8:07 am
^^^Woo! Looks like I'll need to pick up some Brasso. Thanks for the review.
PostPosted: Fri Oct 09, 2009 10:25 am
I've used Comet Sink Cleanser and another metal cleanser in the past to remove print. The Comet can take up to 15 (painfully long) minutes to remove torso print but the other metal cleanser seems to work a bit faster. I'll have to try that rag/piece of wood trick.
Proud member of the Lord's army.
PostPosted: Fri Oct 09, 2009 11:39 am
[quote="Omicron"][quote="shmails"]Oreo - I have not tried to only remove part of a design, but I will test some ideas this weekend and let you know the best way to do that. The cast is off, and the hand is sore but getting better everyday. I have plenty of time for minifigures because I cannot use power tools or list anything heavy for four more weeks. Thanks for asking![/quote]
-Omi[/quote]
I did that too, but the metal around the eraser slipped and gashed the face, so it looks like he has a scar.
PostPosted: Sat Oct 17, 2009 11:54 am
Sweet, gotta get some. I've got an old admiral's bicorn hat (white with printing) that is scuffed and now I can redesign the look.
PostPosted: Fri Nov 06, 2009 10:15 pm
thnks now can you do one on costome decals
myhttp://www.flickr.com/photos/44302124@N02/
luger and dagger solved ww2
PostPosted: Tue Nov 10, 2009 5:41 pm
Thanks for the tip... gotta get me some brasso soon.
Dogs have owners, Cats have slaves.
