It is currently Sat May 18, 2013 9:52 pm
Post a new topicPost a reply Page 1 of 2   [ 16 posts ]
 Post subject: Alternative use for a Dremel Cut-off Wheel
PostPosted: Sat Feb 26, 2011 1:25 pm
Sure, a lot of us have used a dremel tool to hack apart LEGO elements. The cut-off wheels make quick work of ABS, and makes the job that much easier. And we know that once a cutoff wheel gets dull, but not chipped, we just throw it away. I've had a little stack of dull wheels that can't be used on ABS anymore, and I had an idea. This is that idea:
I took three cutoff wheels, used a razor blade to enlarge the pinhole a little bit, glued them together, then stuck a rod in for a handle. I also took a 4L Technic Bar with Stud, cut at the stud and glued the stud to the front. This adds playability and customization: Alone, it makes a decent boss. You could add a stud to it, and have a larger boss. Add a bayonet or similar pointy object, and you get a scottish targe shield.
As far as I know, this is original. I haven't ever seen this done before.
 Post subject: Re: Alternative use for a Dremel Cut-off Wheel
PostPosted: Sat Feb 26, 2011 1:57 pm
Woah, now that is awesome, CB! B) If I had a dremel, I'd do this wippity-quick. I especially like how you glued the stud to the front; very creative.
LEGO Builder, Writer, Video-Gamer, Greaser, History Professor, Swordsman, and Military Collector. I am the Most Interesting Man in the World. :p
PostPosted: Sat Feb 26, 2011 2:20 pm
Brilliant!
PostPosted: Sat Feb 26, 2011 2:31 pm
Great find!
Quis custodiet ipsos custodes?
Check out my Flickr! http://www.flickr.com/photos/oilyanator/
PostPosted: Sat Feb 26, 2011 2:43 pm
Whoa, nice.
PostPosted: Sat Feb 26, 2011 3:00 pm
Thanks guys. Glad you enjoy it :D
PostPosted: Sat Feb 26, 2011 3:09 pm
Well played, sir. Well played.
PostPosted: Sat Feb 26, 2011 3:34 pm
Thanks SV!
Quick mod/upgrade:
Used the handle from a Castle Kiteshield instead of a rod: This works much better, but requires a shield to be sacrificed. The handle from the kiteshields offers better poseability, and just plain looks better.
PostPosted: Sat Feb 26, 2011 11:19 pm
I bet with the texture of the dremel bit that paint would look really cool on it.
"I wish to have no Connection with any Ship that does not Sail fast for I intend to go in harm's way." - Captain John Paul Jones
PostPosted: Sat Feb 26, 2011 11:25 pm
I bet it would. If I had some good paint I'd try. Or if I were any good at painting I'd try X)
