It is currently Sat Jan 31, 2015 3:38 am
Post a new topicPost a reply Page 1 of 2   [ 11 posts ]
 Post subject: Hey, wait a minute............
PostPosted: Sat Nov 14, 2009 1:48 pm
http://www.brickforge.com/store/product ... 395&page=1
On the golf-club display minifig, its arm is megabloks, am I right?
Bass that Crap up!
-Gord, The Dude Movie
 Post subject: Re: Hey, wait a minute............
PostPosted: Sat Nov 14, 2009 2:25 pm
Nope! That's a Technic hose stuck through the torso. This technique only works on the old-style hollow torsos. :)
PostPosted: Sat Nov 14, 2009 2:30 pm
Ahhhhhhhhhhh!! I see that now. It just looks like a megabloks arm :)
Bass that Crap up!
PostPosted: Sat Nov 14, 2009 2:34 pm
It works on Classic space well too.
If the tanks succeed, victory follows. - Heinz Guderian
PostPosted: Sat Nov 14, 2009 2:38 pm
Those are the old hollow torsos. ;)
PostPosted: Sat Nov 14, 2009 2:42 pm
However the torso used in the miniquin is not the old style hollow torso. ;)
PostPosted: Sat Nov 14, 2009 2:47 pm
^ It is also possible to drill out the supports inside the torso.
PostPosted: Sat Nov 14, 2009 2:48 pm
This is true, or you could cut the hose up. :P
PostPosted: Sat Nov 14, 2009 3:08 pm
That hasn't worked to well for me. The hose is pretty stiff, and would have to be very securely attached to the torso in order to be bent.
PostPosted: Sat Nov 14, 2009 4:39 pm
I actually used a 4mm hose for the arms on this miniquin. Although not actually a 'LEGO' product a seller on Bricklink sells multiple colors of these hoses which are the same dimensions as the clear LEGO pneumatic tubing. Hound is correct that you can simply pinch the hose through an old style torso to come up with a single arm assembly which works much better than cutting up the hose into two separate pieces. For this guy I did use a modern torso and drill out the supports.The hands slide right into the ends of the tubing and work great for needing to pose figs.
Users browsing this forum: No registered users and 3 guests
