It is currently Sun May 19, 2013 11:44 am
Post a new topicPost a reply Page 2 of 2   [ 14 posts ]
Go to page Previous  1, 2
 Post subject: Re: skeleton vig
PostPosted: Wed Jul 06, 2011 3:37 pm
It's relatively easy to make them, I made 3 if you count the remake of my first one.
“Democracy is the worst form of government, with the exception of all others." - Winston Churchill
My flickr
PostPosted: Mon Sep 05, 2011 11:41 pm
Oilyanator wrote:
I have recently won a competition with a terminator fig similar to this.
Basically, you have to cut the body at a diagonal so 1 leg pin can still fit in. Doing at a diagonal means it does not effect the neck pin, so don't worry about that for now. For the legs, you want to just take the right leg off but leave the hip bone.
Then cut the skeleton up and glue 1 leg where you took the other one off and cut the skeleton body at a diagonal so it just overlaps and fits into the normal body. Then just glue it all together and paint it.
Alternatively:
For a skeleton more like in the picture, instead of cutting at a diagonal, just cut straight down the middle. As you do this you should be careful to cut around the neck pin like in the picture so the head can still attach. (This should hopefully still leave the leg pin connector compared to the diagonal one.)
Be safe:
I managed to cut myself ALOT doing this fig and eventually used a hacksaw to cut through it. So if you are going to attempt it use a good sharp knife and cut in a sawing motion. Failing that, carefully use a hacksaw. (be careful not to ruin the fig!)
If you want anymore help or pictures on how to do it, you're welcome to pm me!
halo Oilyanator halo
Armothe wrote:
Once you dissect the photo it's relatively easy to figure out what I did. I made a bunch of these 'undead' something like 8 yrs ago and decided to use one of them as a product minniquin. The skeleton body actually fits inside a minifig torso (in this case a really, really old torso) so I didn't have to cut the rib area at all.
Thanks a lot you guys, I made one myself! If I upload it, where do I put it? :?
PostPosted: Tue Sep 06, 2011 1:39 pm
I believe you should put it in the Artisan Gallery.
My flickr
PostPosted: Mon Sep 12, 2011 9:50 pm
Apprentice
Apprentice
Location: The jungles of Lustria, mustering a Lizardman army
I had totally forgotten about this. now that I am getting closer to starting filming, I DEFINABLY need to make some of these.
Cower before my Cold Blooded hoards! For the Lizard-men shall rule the Castle world!
