It is currently Wed May 22, 2013 6:47 am
Post a new topicPost a reply Page 1 of 2   [ 14 posts ]
 Post subject: skeleton vig
PostPosted: Tue Feb 01, 2011 6:16 pm
Wow, 8o , I saw the light gray javelin pic, for the first time, and it is amazing!!!
Does everyone else agree?
Now, I want to make one like it, so far I get the top, but the bottom is really the problem. How do you get the skeletons legs to fit into the "human" figs legs and hips? Maybe <v> armothe <v> could give us a tutorial!
Thanks!
((={:|) (:] -{:[ halo
 Post subject: Re: skeleton vig
PostPosted: Tue Feb 01, 2011 6:37 pm
Now, THAT is cool.
To lego, or not to lego?
PostPosted: Tue Feb 01, 2011 7:05 pm
The pin that holds the normal minifig leg on was cut off and half of the skeleton's leg pin/hip peice was glued in place, or that would be my geuss.
PostPosted: Tue Feb 01, 2011 7:11 pm
Looks like that... A very nice mod...
Semper Fi
PostPosted: Wed Feb 02, 2011 2:39 am
I have recently won a competition with a terminator fig similar to this.
Basically, you have to cut the body at a diagonal so 1 leg pin can still fit in. Doing at a diagonal means it does not effect the neck pin, so don't worry about that for now. For the legs, you want to just take the right leg off but leave the hip bone.
Then cut the skeleton up and glue 1 leg where you took the other one off and cut the skeleton body at a diagonal so it just overlaps and fits into the normal body. Then just glue it all together and paint it.
Alternatively:
For a skeleton more like in the picture, instead of cutting at a diagonal, just cut straight down the middle. As you do this you should be careful to cut around the neck pin like in the picture so the head can still attach. (This should hopefully still leave the leg pin connector compared to the diagonal one.)
Be safe:
I managed to cut myself ALOT doing this fig and eventually used a hacksaw to cut through it. So if you are going to attempt it use a good sharp knife and cut in a sawing motion. Failing that, carefully use a hacksaw. (be careful not to ruin the fig!)
If you want anymore help or pictures on how to do it, you're welcome to pm me!
halo Oilyanator halo
Quis custodiet ipsos custodes?
Check out my Flickr! http://www.flickr.com/photos/oilyanator/
PostPosted: Wed Feb 02, 2011 11:12 am
Okay, having seen Oilyanator's post, use a dremel
PostPosted: Thu Feb 10, 2011 3:32 am
I made a bunch of zombies like that and posted a while back on my brickshelf page. The technique looks awesome!
"I wish to have no Connection with any Ship that does not Sail fast for I intend to go in harm's way." - Captain John Paul Jones
PostPosted: Sat Feb 12, 2011 5:17 pm
Very cool! I don't think that I would want to mutilate a torso to make that though.
My Blog: Making Alternate History
PostPosted: Wed Feb 16, 2011 9:12 am
Once you dissect the photo it's relatively easy to figure out what I did. I made a bunch of these 'undead' something like 8 yrs ago and decided to use one of them as a product minniquin. The skeleton body actually fits inside a minifig torso (in this case a really, really old torso) so I didn't have to cut the rib area at all.
PostPosted: Sun Jul 03, 2011 1:57 am
Apprentice
Apprentice
Location: The jungles of Lustria, mustering a Lizardman army
I might have to use that technique for the zombies in my castle movie.
Cower before my Cold Blooded hoards! For the Lizard-men shall rule the Castle world!
